You need another EK harness. LS harness only goes from the engine sensors to the shock tower but an EK harness goes all the way to the ECU....One piece. But you will run into problems with the dizzy, injectors and alternator b/c the plugs will be different. You can splice them in or get OBD2A Dizzy, Alt, Injectors for a B18B1
