Quoted post[/post]]
no, keep everything you already have in your car. keep the same pump, keep the same hoses, keep the same belts, etc. the only things you'll change are the brackets that bolt the p/s pump and the a/c compressor to the block. use the brackets from a Del Sol DOHC Vtec.
