+1Quoted post[/post]]
check wire continuity?
It sounds more like a bad ground or a wire short.
My VSS CEL came on, it was full of water, dried it out and cleaned it up, works great.
PS: It's NOT your cluster, your cluster doesn't care whether or not your VSS is working, and your ECU doesn't ask your cluster whether or not your VSS is working, it checks the sensor.
Cluster has not a thing to do with VSS signal.Quoted post[/post]]
He has answered your question. If you aren't familiar with wiring, have someone look at it for you.
Quoted post[/post]]
I disagree.Quoted post[/post]]
Quoted post[/post]]
will if the cluster is bad it will not take the signal from the vss there for not working
No.Quoted post[/post]]
wont a bad cluster set code? i think it would if it could not recive signal. if the ecu send signal to cluster and cluster is inop wont the ecu see the problem, then set code.
