pnoytegn707
Im parting out my gsr motor or selling as a whole. Im going with different setup with my ek hatch, decided to go ls vtec turbo.I can sell whole swap with tranny for $2500. It will include obd 1 dizzy and alternator and obd1 engine harness, plus obd1 P72 chipped. Axles,shift linkage included. Everything below.Blox gsr intake mani is already sold which is pictured. Stock gsr im will replace it.
Option 1- Piece by Piece
$700 -1997 USDM GSR BLOCK around 50k WITH VIN LEGIT WITH RECEIPT
Usdm itr pistons with itr rods used for 5k miles-Excellent condition
Brand new Oem Piston rings set
Brand New Oem Honda bearings
Brand new Oem Headgasket
$650-Y80 Gsr Tranny excellent condition-no pop outs or grinds, shifts perfectly
ACT Extreme Duty CLutch with Street Disc (AI4-XTSS) Used 3k miles
Pro Street 8.58ilb Flywheel
$750 Firm-1997 usdm gsr head built will include Throttle Body and all sensors, Aem Short Ram Intake and Stock gsr intake manifold obd2, Brand stock gsr header, fuel rail, gsr injectors. Car will not include obd 2 dizzy or alternator.I will include obd1 dizzy and alternator. All of the parts below are already installed on the longblock.
Fresh from machine shop
Clean and Resurface Head/Pressure treated head Like New
Valve Job
New Valve Seals
GSR stock IM
New Honda Cam seals
New Valve Cover Gasket
Jdm ITR valve cover (Real)
Integra Type R Cams
Stock gsr valvetrain
Aem Red Short Ram Intake
New Oem Timing Belt/tensioner/spring
New Waterpump
New Spark Plugs
Gsr TB
Starter
$150 USDM obd 1 p72 gsr ecu Chipped to GSR Specs
Will include obd2a p72 ecu for those who want to bar
I will also have shift linkage,axles.
Decided to go with a LS VTEC Setup since its already built for boost. , the reason why im selling.
Serious buyers only. Give me a Call if interested Paul 707-315-3612. Im Located IN Vallejo and Concord area. The Gsr motor will be located at the shop in Concord. Motor is on a cherry picker ready for pick up.
Option 2
$1800-1997 Usdm gsr longblock motor. It will include the head above and shortblock minus tranny. I will include obd1 dizzy and alternator. Sorry no engine harness. Will include obd1 engine harness. I can work a deal and include the obd1 p72 ecu for $1900. I have the receipts from the machine shop labor and parts replaced.
$650-gsr y80 tranny complete with speed sensor.
Here are some pics of the motor.
Here are some pics I took after the head went to Machine shop
Here are some new pics. Sorry the pics are blurry. You can come see for yourself at shop. Excellent working condition.
Obd1 p72
i am willing to ship at buyers expense
Valve Job
New Valve Seals
GSR stock IM
New Honda Cam seals
Integra Type R Cams
New Waterpump
New Spark Plugs
Gsr TB
Starter
Option 2
Obd1 p72
