Fuel injector questions?
  • Thread starter Thread starter 34diesel34
  • Replies Replies 9
34diesel34
Import Tuner
I'm putting my B16a in my 91 crx si tomorrow. It's the OBD1 sir2 B16a. I've already been converted to OBD1 with the sohc vtec (A6 block Z6 head)that I'm pulling out of the car. I was using OBD0 injectors with this setup. I'm planning on using the OBD1 injectors that came with the B16 I have. Do I need to remove my resistor box now, or do I keep using it with the new setup ? Will the stock crx si injector plugs plug into the OBD1 injectors? please help:huh:
remove the resistor box and dremel the plugs to fit the new injectors or the injectors to fit the plug, I can't remember which it is.;)
sure will there the same, and with those you wont have to delete the resistor box. but thats easy to do. either way its simple
