Fuel pump failures
  • Thread starter Thread starter CRXSIR1
  • Replies Replies 3
CRXSIR1
I have gone thru 2 walbro fuel pumps and now a stock honda pump in five weeks. Any Ideas? 90 CRX Si with Stroked LS VTEC, B18b, ITBs with vacumn block. Thanks in advance.
Dirty fuel causing the fuel pump to work harder, maybe? How did the filters look when you pulled the pumps out?
Also, have you tried testing the pumps after taking them out? ie: problem is actually the main relay or something?
Check your grounds. a poor ground will cause the pump to burn out in no time flat.
