gas octane
  • Thread starter Thread starter valiente
  • Replies Replies 6
  • Views Views 912
valiente
hey i was wondering i did a d16z6 swapped into my ef and was wondering what kind of gas should i use. is regular ok?
^Yep. Higher octane gas does nothing for a stock motor, and can actually be worse for it in the long run, no to mention harder on your wallet.:D
cool thanks. one more question how ever im trying to replace the diz and when i pulled it out there was oil coming out of it, is this normal and how much will come out or do i have to drain the oil first.
Yeah it will leak some when you take it out, just put a rag in the hole and check your oil agian when you put it all back together. Its just the oil laying in the top of the head, I would say you wont lose more than half of a quart, but still check and add if need be when its back together.
forget gas octane.
put in CNG.... it gives u 35 hp
<_<
