gsr issues
  • Thread starter Thread starter SoSlo
  • Replies Replies 1
  • Views Views 985
SoSlo
iv got a few ? about a gsr swap into a 93 vx hatch. what more do i need besides: upper 94gsr radiator hose, lower 94 del sol hose, 94 gsr throttle cable, intake, motor ecu, axles, shift linkage, trans?? also can i use the bottom part of the vx exaust manafold with the gsr upper portion so i dont have to weld the cat right away or wont that work?
any thing im missing i would be greatfull.
the exhaust wont work like that... the cat on gsr's and most honda motors is after the downpipe.
just make sure you get the mounts with the motor and you need to convert your 02 sensor to a 4-wire
