guage install ?
  • Thread starter Thread starter Delsol94
Delsol94
i jus got an a pillar guage pod and a water temp and oil pressure guage for it and want to kno where to tap in to install the sending units on a d16z6, please help im trying to do this today
Didn't anything come with directions? Take your time and read around first please. It's been covered.
The oil pressure gauge does not use an electronic signal to determine oil pressure. The honda oil pressure switch is just that, a switch. On/off only. You need a sandwich plate for the oil filter that has a tap to run a hose/pipe to the gauge sensor.
The coolant temperature gauge you can connect to the sending unit wire which is typically red/white and located by the thermostat.
