h22 need help with swap eg donor
  • Thread starter Thread starter TEAM JDM-P
TEAM JDM-P
Ok i bought a crash eg hatch with a h22a swap i still havent taken the motor out i want to drop it into my ek hatch what can i use from the eg to make the swap easier i know i use the shift linkage and shifter assembly but what else can i use. The motor is from a 95 prelude so ill need the obd2a to obd1 conversion harnest, hasport axles and mounts . Any help will be appreciated how will I go about wiring everything up thanks.
What i would do(and will be doing as I will be doing a h22a swap soon) Is get a "repair manual" for the car the engine came out of(the prelude) that or get a wiring diagram of the internet(google ftw) and then print them off and match up wires using a diagram such as wire-a going to here matches to wire-b on this one.
Sorry i cant be more help. I also hope you swap goes over well.
