racingtopher
I am having problems with starting my car.
I have a B16a OBD-1 in a 91 civic.
Sometimes it doesn't want to start, clicks.
I changed the starter to a 2000 GSR starter and still have the same problem.
(The GSR starter did not bolt right up, like someone said it would, had to change mount brackets around and use less screws.)
Connections are good.
If I slam the clutch down hard and turn the starter at the same time, sometimes it will start.
After I get it started once, it starts just fine, one crank, no slaming the clutch.
Does anyony know whats wrong?
