have problem with car stalling
  • Thread starter Thread starter ilwill
  • Replies Replies 1
  • Views Views 692
ilwill
when ever i am coming to a stop and i push in thr clutch or take out of gear the rpms drop all the way down and sometimes stalls it even hapens when i am just siting there and give gas then let off .only have problem when moter is warm any ideas?the moter is a gsr b17
Check everything associated with the idle, I am not familiar with the b17's but throttle body, idle set screw, any wiring/vacuum connections in the area. It just sounds like your car is not catching it idle when its spinning back down. You might even try turning the idle speed up a little bit as a first (and free) thing.
