Head Light Prob
  • Thread starter Thread starter chap_e77
  • Views Views 818
chap_e77
I have a 95 hb and one of the headlights went dull. I changed the bulbs and checked the fuses but the driver side headlight is still dull. does anyone know what the problem is. Any help would be great.
check the connection points inside the plugs... they are probly dirty... carefully clean them up and this should fix the problem
do you have access to a multi meter? Check the voltage and compare it to that of the other head light.
I reluctantly had the same problem when I first acquired my car. Make sure there is a good connection in the plug and the wire is in good shape. Make sure the plug is a tight fit metal to metal for power, if bad you can purchase one at a junkyard and splice them. I did a lil different( purchased whole new hid harness).
