HELP! Clutch Replacement
  • Thread starter Thread starter AlphaCivic
  • Views Views 998
Hey folks. Me and my mechanically inclined friend are swapping in my new tranny and clutch today and we need to know the correct procedure for clutch replacement. mainly the hydro clutch fluid changing and whatnot. my friend has done swaps and stuff be4, but always on cable trannys. whats the difference and what do we need? please help asap!
thank you =)
changine the clutch fluid is just like changing brake fluid
there is a little valve on the slave cyl just like the ones on the brakes
just bleed it through till the fluid is nice and clean.... fluid should be changed in both the brakes and the clutch every 6 months to 1 year depending on how hard / how much you drive
