endlesszeal
ahh.. okay.. thought so..
whats the model for your RAM?
if you RAM voltage AND timing is in spec, you can either:
A)-RMA (return because bad modules)
B)-loosen timing (changing value to higher number, usually the first number CAS helps most for stability) and choose T2 timing. also, give it a slight bump in voltage. look up your model and see what OCZ allows for voltage adjustment. usually theyll let you go up to .10v before voiding warranty.
