HELP!!-converting 7 wire O2 to 4 wire O2.
  • Thread starter Thread starter SpoonTuNed
  • Replies Replies 8
SpoonTuNed
I have a 96 HX coupe which has 2 O2's a 7 wire and a 4 wire. I swaped out the hx motor with an EX motor but still used the HX harness. I am runing a EX ecu now also and want to know if i can convert the 7 wire to 4 wire O2 and if so how can it be done? Thanks
...So i guess this is impossible or did i miss something?
Quoted post[/post]]
buy a 4-wire 02.
wire it into the correct pins. ignore the harness.
done.
Would you happen to know which 4 wires out of the 7 hook to the 4 on the o2 sensor? thats basically what im after. thanks
Quoted post[/post]]
you are not gonna get very far talking crap if you look you will find it, it is not that hard
https://hondaswap.com/forums/index.php?showtopic=14242
Well anyways thanks, thats all i was after...I guess i should've looked harder. Thanks again!
Is there a way to distinguish the senosr voltage from the heater control? I believe they're both black wires.
