I'm trying to identify the valve springs in my motor. I can't say they are OEM because those should be identified with paint. I need to verify this so my head doesn't explode at 9500 rpms running high lift cams. The motor is a b18c-r and has the stock cams.
I cracked the motor open and found S2 titanium retainers. Why would someone upgrade the retainers if they are running stock cams?
Here are the springs:
