thegreatinto
I own a 2000 Honda Passport 2W-drive and I have a question and was wondering if you can offer me advice because I would really like to fix it myself.
The car recently - when going from reverse into drive - FEELS like it goes into gear BUT when you press the gas pedal it lags then jumps forward as suddenly engaged in drive. Then last night the check engine light came on. I then came to a stop light down the road - stopped and then when pressing the gas pedal it vibrated violently. THIS more than anything scared me.
Here is some history on the car: I bought it used two years ago - I have never checked the trans fluid. I wonder if this could be a problem.
About 4 months ago, I had a fuel pump replaced because the original had gone bad - even since it was replaced it has never started right (slow start). EGR valve was replaced at the same time because IT had gone bad as well.
WHAT IN THE WORLD is going on with this car. I am so sick of handing it over to mechanics to be fixed - when problems continue to rise with this car. I don't know what to do and was wondering if you could offer advice?
Do these symptoms ring a bell to a more pin pointed problem that could be getting overlooked which could be the main cause of these avalanche of issues? An electrical problem? A low trans fluid problem?
Please help!
Thank you,
Erin
Please help!
Thank you,
Erin
