buggaboo99355
does anyone have a 1992 auto accord? how does it drive?
my car feels like it has no power at all. i know autos dont distribute power good, but this is horrible.
the timing is set perfectly. but when the car warms up and i step on the gas...nothing...3-5 seconds later it starts to move. it has very good speed when it starts moving and easy to accelerate when rolling.
what do you think could be the reason for my loss in power i am running out of ideas. i cleaned injectors, reset the timing perfectly, the motor has very good compression, changed timing belt with water pump, put new plugs and grounded the engine.
should i look into a venom chip, msd ignition, or one of those cheap 1.00 resistors on EBAY???
HELP HELP HELP HELP HELP HELP
AND ALL OF THE FLUIDS ARE AT THE RECOMENDED LEVELS
How does the car roll on its own? What does the rev counter do when you mash the gas pedal from a start (in Drive)? How does the engine respond if you hit give it lots of gas at idle? Do revs climb quickly? Have you checked for excessive slack in the throttle cable? Just giving ya some ideas...
