Help
  • Thread starter Thread starter vago760
  • Replies Replies 3
vago760
Okay i almost got my 89si b16 runnig just did the swap.. First i would like to thank everyone for the help to get to this point.
My car was idiling really bad and my car was in limp mode. I replaced all the sensors including iac vavle.. my car idle's way better now but its in still limp mode and now im not sure where to go from here.. and i already checked i did not get the map and tps mixed up, i checked... Any advice would help and thanks for helping me get this far cuz of everyone
Does anyone think i have to run the car for a bit see if the ecu clears its self from
limp mode- i don't have a cel light so i can't check the codes
I think the ecu error code will only clear if you remove power from the ecu for a while. You can just take the negative battery cable off for ten minutes. Then if you get the cel again, read the code and go from there. I would clear the codes and then see if you get another error code.
