Help!!
  • Thread starter Thread starter 69crx69
  • Replies Replies 3
  • Views Views 763
69crx69
SO I switched my rex from obd0 to obd1. I have a obd1 dizzy and a chipped p28 with a adapter harness. I hooked everything up and I dont get any spark. I believe I am getting fuel, because I can smell it. I rechecked my wiring on my dizzy and its correct. I even swapped the two white wires around, because I know that if their swaped, the car won't start. I am thinking it is the ecu or the harness. Anyone else have this issue????
Check to make sure all of the connections you switched at the ecu are making good contact. Its also not impossible that your distributor is junk. If you have a extra laying around try it.
found out that it was a faulty ecu that was the problem. Swapped them out and the cvar runs like a champ.
