urrrghhh, im so pissed, i was attempting to install my hasport mounts today to replace my shit place racing ones. easy right? think again. i jack the engine up on a jack and i start at the drivers side mount. i remove the mount, but i must also replace the engine bracket holding the mount to the engine so i can utilize the hasport mounts. so i get the mouth off. no problem, but then when i try to remove the bracket from the engine, it all goes down hill. now il working with a basic socket set and space is very tight. i find myself wailing on the wrench with a hammer to try and loosen these bolts, but not one of them will budge. luckily i was able to put it all back together to save for another day. how can i do this without taking the entire engine out of the car?
 I swapped brackets using air tools while the motor was still out of the car, but I know-- hindsight is 20/20.
   I swapped brackets using air tools while the motor was still out of the car, but I know-- hindsight is 20/20. Good luck, man.
  Good luck, man.
