how to make y8 intake manifold work on swap
slammedb18acivic
now we all know the y8 is obd2. but is there a way i can make the y8 manifold work because the piping is bigger. there is a plug on the 94 manifold that the y8 doesnt have. any suggestions. can i eliminate the purge valve? thanks alot for you help
no, you will throw a code if you elimanate it.
just mount it on the firewall, and give it a vac source.
[post=507615]Quoted post[/post]​
you are talking about the IAt sensor. on the 6th gen, the located on the airbox, and not the manifold. drill and tap the y8 mani on the huge flat spot on the 1st runner (side) this is waht I did. pretty easy!
matt
