IAC Valve Question, help please
  • Thread starter Thread starter BigZeke5
BigZeke5
Guys, I have a 92 eg civic with a 99-00 civic b16a2 swap. My IAC or idle air control decided to take a crap. I took it out, cleaned it with brake cleaner let it sit for an hour under a fan and nothing, si I am in need of an IAC Valve.
What I would like to know is, what other engine has the same Iac valve that I can pull it from and install it on b16a2 IM? Any and all help is greatly appreciated.
THANX!!! :)
Positive. When I cleaned it out and put it back on before I turned on the car, I had no light on in key on, engine off. The very minute I turned on the car, the light came back on. Turned off the car, checked for codes and I got code 14 which is the IAC Valve. Its the only code on right now.
