Idle problem in my B20/vtec???
  • Thread starter Thread starter CRVTEC EG
  • Replies Replies 7
  • Views Views 7K
CRVTEC EG
I have a GSR head on a CRV block......When i start the car, the revs jump up to 3k then they start bouncing from 1k to 2k rpms, it doesn't go away after the car warms up. I'm leaning towards a bad TPS sensor but i wanted to see what you guys thought........thanks a lot
steve
check the pcv, iab, or iacv, or it could be the tps just check there voltage and also there vacum to make sure its working properly.
my swap did that too(h22).. i messed with the tps and idle screw
dont know which made the diff.. i think tps
isnt the fix to measure ohm or somthing?
YA THATS WHAT I MEANT TO SAY JUST CHECK THERE OHMS AND ALSO THE VACUM OF THEM.
OK, got it guys, there was a loud squeling noise coming from the intake so i took it off and i covered the holes in the throttle body with my fingers and it idled like normal.....so i took the iac apart and the white plastic part inside that screws in, was lose and it fell out, i tightened it and put it back togehter now it idles the best it ever has.
Thanks for all the help
steve
