Hello again. I've come up with another problem with my 95 ex civic. I'm sure someone can help me with this one as well.
ok... most cases it only happen after hitting high rpm's and after coming to a stop my gas peddle feels like its stuck. I have to give it a slightly forceful pump for it to come loose. I thought it was the throttle cable get'n stuck within the plastic casing but a few months ago my throttle cable actually snapped and had to replace it. Problem still there. After that I tried greasin' up the "throttle catch?" (that thing you use to rev your engine from under the hood) But that didn't seem to do anything. Now just to give you an idea of how much it gets stuck... the gas peddle doesn't bend to the floor and spring back... it just doesn't go anywhere untill i kick it.
On the other hand, there are times that i'm just cruisin' to work through traffic (1st gear, 2nd gear, 1st gear... stop n go.) and I can hear/feel my engine idoling higher than it's supposed to. I give my gas a quick tap, its not stuck, but i hear/feel the idol go back to normal.
Any and all opinions are appreciated.
Marcusâ„¢
Marcusâ„¢
