HATCHET_HONDA
scottie fizzle
anyone know how the bushing kit is installed into the innovative traction bar on an ef? im confused on where the big washer goes in between the bushings
is this the replacement crossmember or the full aftermarket one?
Also, if it's the aftermarket one, I had the big washer in my Avid kit too....never knew where it went and they never told me(just said they would send me new instructions...which didn't say anything about the washer).
They should go outside the bushings so it compresses them.
2 washers and two bushings. The washers are on the outside. If you look at each hole you will only see the washers when installed correctly. The tightness depends on where you want the wheels to sit as this is for adjusting when aligning the car.
