jdm b18c type r into 96 coupe with d16y7
  • Thread starter Thread starter fuzzy
fuzzy
i have just got myself a full crashed 96 jdm type r integra and want to swap it into my 96 coupe with a d16y7 engine. whats the easiest way to do it and what do i need?
Check out hasport; they have the mounts and shift linkage you need. You will hafta decide wether you want to do obd1 or obd2. Both will require you to make changes to your current setup.
I did that exact same thing only with a 98 spec itr... the only part you really need is the rear mount from 99 civic si.... everthing else you can do with a mix of the itr parts and the d16 parts... If you need specifics let me know.
Yea, ther's no need to spend the extra money on HAsport mounts, you can use the stock ones. And if you have the whole car, you have everything you need already.
