Jdm Engine And Wiring Harness
EdrikLongtail
For a 89-91 b16 sirI compelet change over, For the wiring can i use the usdm harness with jdm plugs or can i just switch the hole wiring harness over and try to make everything fit?.
use the USDM harness swap any plugs that dont work with the JDM harness
for any wires that need to be lengthened just steal them from the JDM harness
Are u sure ?
i think USDM and JDM harness will same. Only USDM ecu s has more some sensor so usdm haness has some more cable and the jdm ecu side of this extra cables is empty
Any ideas ?
use the usdm, the jdm is all on the wrong side and wont reach
Any ideas ?
The JDM harness is for a RHD car, which means all the plugs are on the opposite side of a USDM bay.
Originally posted by civic_01@Jun 15 2003, 07:47 PM
hello my name is angel, I barely bought a b16a but im having problems puttting the ecu into a 91 civic std
start your own thread. this has nothign to do with this thread.
Anyway...
Do what E said... use your car harness, and swap plugs where necessary.
we have a dx to SiR conversion article on the site. I suggest you browse around
