Originally posted by tab@Dec 22 2003, 12:52 AM
reference section. Engines. Black top, 200 hp Red Top 220.
Both JDM, one is slightly better massaged at the factory. More than likely, unless you are spending a lot of $$$$, you will get the 200 hp, 161 lb. ft. torque model.
Originally posted by Jshade@Dec 27 2003, 09:49 AM
http://www.geocities.com/tjautobc/engines_codes.html
Originally posted by h22freshman@Jan 6 2004, 12:22 PM
One of the major differences between the two are the pistons i believe, the red valve cover engine has nigher performance pistons.. runs at a slightly higher compression due to is ability to over the black valve cover engine. Also the 220hp vesion of the h22 is called a Type-S.
Originally posted by dohcvtec_accord@Jan 6 2004, 10:43 AM
Type S engine also has a hand-ported intake manifold, better-flowing head, upgraded valvetrain, slightly more aggressive cams, a better-flowing exhaust manifold, and slightly better connecting rods.
