Brand new kit going on a D16Y8.
First, here's a huge reference picture I took: PICTURE.
Above the J of Jackson is a brass plug and two threaded areas. I've learned from some research that the middle thread is for the Boost Pressure sensor. Are the other two outside threads used for anything?
On the right side is two nipples and a block off plate. I read this block off plate can be removed on 92-95's so directly mount the T/A sensor, but for me I leave it blocked off and use the T/A sensor in the intake. Is this correct?
Two main problems right now: How do I remove the crankshaft pulley? I have an impact wrench on it and it won't budge.
When and how do I install the extra idler pulleys that are supposed ot the alternator? I'm assuming the JRSC IM/SC has to be removed for that. But how does it mount? The JR instructions are completely lacking in this area.
This is a H-T thread I just found and am using for reference: http://honda-tech.com/zerothread?id=1283655
More questions tomorrow when I get more pictures.
