lower motor mounts
  • Thread starter Thread starter apotmesil
apotmesil
I have an EK with a b18c5 swap. The lower motor mount (the rubber ones) on my drivers side has broken. I wanted to replace them but was was wondering if i need to buy them for a civic or integra? Also does anyone like energy suspension make these mounts? Thanks
They're the same of D and B series. You can even try the trans side torque mount on the driver's side
(need to use about a 1/2" slug added to make fit correctly)
Its much stronger and these mounts can go out pretty easy with stock mounts.
You can get aftermarket ones too ($$$) and they're super stiff.
New correct one for your car is about $45
Recycle yard one $20
