97EK
formerly LSVTECCRX
Hi. Im installing a Pursuit Pro9055 remote start on a 2010 mdx. I am not using a transponder bypass though. There are 2 features i use when installing these remote starters, 1 wire pulses ground before starting (unlock or disarm) and the other wire pusles ground while starting (lock or arm). The only problem is the lock/arm and unlock/disarm systems arent switch to ground circuits, they get a command through the B-CAN system to lock or unlock. I need to figure out how to make these features work. Any suggestions?
