94accordpower
ricardo
what do i have to do to unlock my motor to get the full amount of powor out of it?
um... did this happen after you changed something? your not giving a whole lot of information. When did this start happening? do you have a CAI on your car and have you recently driven through alot of water?
What ECU are you using?Up, Up, Down, Down, Left, Right, Left, Right, B, A, Start.
:rotflmao:Up, Up, Down, Down, Left, Right, Left, Right, B, A, Start.
You probably broke a valve-spring. Just take the oil-cap off, and put both tubes of JB-Weld into it, then you should be good to go. Just run it at about 5000 rpm for about a minute in the driveway, then bring it up to 7500. Should be good to go.
check to see what codes your trowing, then if that doesn't fix it you prolly need a new dizzywhat do i have to do to unlock my motor to get the full amount of powor out of it?
