In this case I would have to suggest a yamaha 1,000cc from an R1. Then weld a sproket to the front diff. 15,000 rpm sequential goodness!4g63t swap.
don't do the turbo for power, do it for mileage!
leave it to full-race to have this segment owned too
http://ecomodder.com/forum/showthread.php/1994-honda-civic-d15-3-stage-vtec-turbo-11881.html
exhaust a vac leaks can hurt fuel economy.
what oil is speced for it? i'd assume something like a 5w30. generally thinner oils give better fuel economy, but it's a small difference.
I pretty much did everything I could as far as a tune up goes. I'm going to check the timing next time I'm at my dads and make sure that's where it should be. The only thing I didnt replace was the coil itselfProbably could use a tune up. My sister gets 55mpg with hers.
I get around 40mpg in my civic still.
