I just swapped my obd-1 distributor for an obd-0 distributor because the obd-1 will not work with my pr3 ecu...i was told to do this since i have an obd-0 chassis with an obd-1 motor running off an obd-0 ecu...everyone follow that??
now my question is do i get first gen plugs (the wire harness side) and put it on that way so the distributor plugs in? or is there another way to do it? if i need the harness side plug...do parts stores sell it or do i got to go chop it off another motor? any help would be good here...thanks
