my motor in my 94 honda accord ex coupe went bad on me so im decidin on the h22a obd1 engine swap so i need advice on the parts needed for swap?i wld really appreciate it
It's really a bolt-in affair. The stock mounts can be re-used, although you can upgrade to the Prelude mounts or after-market mounts if you want something a little beefier. Other then that, it's pretty much a straight bolt-in...
your also gonna need a 94 lude driver side mount. Throttle cable w foot pedal from lude (94). p06 chipped w h22 basemap. h22 distributor housing w internals from a 94 d16z6. lastley make sure your fuel injector resistor box is wired up rite cause w/o it it will never start. make. make sure to put new auto-tensioner as well when ur replacing timing belt,change water pump too.
