Need help!
  • Thread starter Thread starter Lender69
  • Views Views 565
Lender69
My engine is acting funny. When I turn on the car it starts to choke and then I smell gas? Does that mean my injectors are bad or my fuel pump? Can someone help me. Thanks :worthy:
more info....engine? what did you do to it? what did you touch? any codes? be carefull and look for leaks...
This is what I have on my engine AEM Fuel Rail, B&G Regular, fuel gauge, AEM Cam Gears, Header, DC Sport front/back struts, No PR & AC, MSD spark plugs and JDM ECU. My p72 got messed up with I chipped it. So that is still being fixed. The engine by the way is a GSR. It was working fine but one day when I took it out to drive I heard a sound like two bolts fell inside a pipe. After that my car started choking and smell like gas. A few days after that my cousin when to check on it. When he turned on the car 2 cable caught on fire. He was able to turn it off before it got inside the car. He changed those wires but it is still making sound and smell. Any info you can give me will be useful and thanks again for your help. :worthy:
