i just swapped a 1st gen jdm b16a w/ hydro gsr tranny into my '95 dx coupe. the ecu i'm running is a p28 running uberdata with the vtec pressure switch disabled. i have the hasport vtec subharness, i ran the green wire in the harness from the vtec solenoid to pin a4 on my ecu. it's throwing a code 21 (vtec solenoid) and i can't seem to figure it out. i've even tried running a wire stright from the solenoid to pin a4 without the subharness just in case hasport screwed up somewhere but that didn't work. i know uberdata is all chipped right 'cause my rev limiters i've set are working. i tried running direct power to the solenoid and it popped fine. i've checked the screen on the solenoid and it's clear as can be. i'm running out of things to try and am hoping that somebody here can help me out. thanks.
