alterxerxes
Having some problems with this swap. All of the connectors on the passenger side compartment fit except one.
One connector is 3 wire (from the car) and the other is 2 wire (from the engine). Does anyone know how to modify this?
Does this have to do with the iacv fix in the swap section (that I can't seem to start a new thread in)?
If so, wouldn't the ecu conversion need to be taken into consideration in swapping the pins?
