obd1 o2 sensor
  • Thread starter Thread starter ^crx^
  • Replies Replies 6
^crx^
what kind of o2 sensor do i need for my odb1 setup?
how do i wire it if im running one wideband sensor and only one o2 sensor to the ecu, would i cet a check engine ligth then?
What wideband? if you are just trying to run a wideband, get one of the ones like the PLX that is standalone, drill a bung into your header and run it independent. If you want to use it as you o2, you need to run a capacitor so your ECU see narrowband, but your reader sees wide.
okay, aint it better to drill the hole in the down pipe so i can read out of all four cylinders?
yeah, it should be just before the car on the downpipe.
you can run a wideband AS your o2, or you can run a wideband WITH your oem o2.
as john said, its all in the wiring.
