Question about building my block...?
  • Thread starter Thread starter NeedACivic
  • Replies Replies 3
I have a JDM B18C in my 92 Hatch, and i am about to take the head off in about a week to have it ported, so i thought i would build the block a little too. I am getting the Rev Hard 2C kit this spring and i am planning to run between 8-12 psi. I just wanna put in a block gaurd, arp head studs, and a turbo head gasket. I think that should be plenty of a build for 8-12psi on my block. My question is what brand of head gasket, and block gaurd should i buy? And is that all i will need to run that much boost? Thanks for any replys!
-Cody
stock headgasket
no block guard
11 psi or less (so you don't have to run a 3-bar map sensor)
440 cc injectors
hondata system tuned by a pro.
you'll be fine
