i just got my jdm b16a2 motor installed, but i didn't come with the throtle cable bracket. the one off the d16z6 won't fit on there. will a del sol bracket fit on there? do i have to also use the del sol(could i use a ls cable or a 99-00 si cable?) throtle cable or can i still use the stock ex one? also i have another problem. the check engine light doesn't come on even though the o2 sensor isn't screwed in the bung. what can cause this to happen. could the o2 sensor be broken? other than that the car runs perfectly and pulls really hard, no weird noises and no grinds unlike the d16 i had in there with a tranny that had bad sychros. also do you really have to hook up the purge solenoid? i heard that its only for emissions. btw the car is a 1994 civic ex.
Thanks
Thanks
