I Ignorant import guy Senior Member Feb 4, 2006 #1 What's the difference between shift linkage and shift cable? Is there a difference? Would both be needed in an automatic to manual swap
K2e2vin Senior Member Feb 4, 2006 #3 Ignorant import guy @ Feb 4 2006 said: Quoted post[/post]] Would both be needed in an automatic to manual swap Click to expand... What kind of swap is it? H/F/K series use cable shift linkages, D/B uses solid linkage.
I Ignorant import guy Senior Member Feb 4, 2006 #4 K2e2vin @ Feb 4 2006 said: Quoted post[/post]] Ignorant import guy @ Feb 4 2006 said: Quoted post[/post]] Would both be needed in an automatic to manual swap Click to expand... What kind of swap is it? H/F/K series use cable shift linkages, D/B uses solid linkage. Click to expand... I am going from a d16y8 automatic to a b16a2 5 speed (don't know the transmission codes)
