Swap or turbo
  • Thread starter Thread starter Gimpo
  • Views Views 851
Gimpo
should i go thru the time and money to put a 99GSR vtec into my 91 LS or should i sell the motor and boost the LS?
boost, you'll make a lot more hp. For the price of a GSR motor swap you cold get a turbo setup, built bottom end, and hondata. (assumeing about $5000-$6000 for the swap). Or you could go the rout of ls/vtec...and then boost! :D
I'd build the bottom end, boost the hell out of it, use hondata, good clutch, and LSD. Then buy some turbo cams later.
