Swap
  • Thread starter Thread starter ad daddy69
  • Replies Replies 9
  • Views Views 754
ad daddy69
i have an acura integra 91 and i was wondering what u would suggest for an engine swap on it. I was thinking of doing the ls/vtec or the b18c. any suggestions?
Originally posted by ad daddy69@Apr 15 2003, 04:40 AM
how much do the b17s run for
IF,you can find one I would think they would go for about the same as a newer B16,maybe more.
i was thinkin towars a b16, gsr or type r engine im askin what ones to u think will easily be tuned and cheaper to do? also which is the easiest and cheapest to drop?
b18a is the cheapest and easiest cuz it comes with a cable tranny, not hydrolic
obd1 b18c1 is expesive and a little trickier and you still need a cable tranny
b1c5 is much more difficult and you still need a cable tranny
b16 is torquless
i want to swap a type r but what all will i need to buy and what do u think the total cost will be with everything
He already has a B18A1 :huh:
since you already have an ls motor, why not build the motor up a bit (ie: bottom end) and go lsvtec? just a suggestion.
i was gonna go ls/vtec but then i was thinkin that would end up costin around 3500 and for only about 1 or 2 more i could get a type r. but how much do u think the ls/vtec would cost me?
