teg calipers and rotors on stock cx hubs?
  • Thread starter Thread starter vtecsir1
  • Replies Replies 3
  • Views Views 835
vtecsir1
i searched for this and didnt see the exact question or answer im looking for.
teg calipers and rotors on stock cx hubs? i have a 95 cx and was wondering if i can just take the calipers and rotors off and put integra calipers and rotors on. will i need an extra bracket or something or can it not be done at all.
NO. this will not work at all.
You'll run into fitment issues as in the integra caliper will not fit onto the CX knuck/hub assembly --- the offset is off by a few cm's.
If you want to use integra brakes, you need the whole integra knuckle & hub assembly or the knuckle/hub assembly off of a 92-95 civic coupe with ABS (exactly the same as Integra knuckle/hub assembly).
