Tps help
  • Thread starter Thread starter OBD0SiR
  • Replies Replies 3
  • Views Views 632
OBD0SiR
I have a JDM B16 gen 1 in a 91 hatch and I am trying to calibrate my tps. For some reason i an getting 4.3v at idle and .8v WOT. itried switching the outter wires and i get .01v at idle and 3.1v WOT. i have tried moving the sensor around to calibrate it and that is the bst reading i have gotten. i dont know if this is a wiring problem or a bad tps.
It should be .5v at idle and 4.5v WOT, it may be a bad TPS if your getting low readings and youve adjusted it either way through the range of adjustment.
thats kinda what i thought. i am getting a 5v reference and i have adjusted it all the way in both directions. i just didnt want to buy a new one if it would be something else. thanks
Take the tps off and when you put it back on make sure the black piece of the tps that rotates goes in between the 2 metal holder things on the throttle shaft.
Rotate the throttle slowly. Does the voltage change gradually?
