Turbo Chargers
  • Thread starter Thread starter civic3
  • Replies Replies 3
  • Views Views 780
civic3
Hey I am looking for a little info. I was wondering which is better to use a copper head gasket or a metal head gasket when running boost between 8-15 Psi.? So if you have any insight that would be great. Thanks
Stock or Cometic Gasket's head gasket. THey are built the same, but if you can't put your hands on a stock one, Cometic is the way to go.
Spray the Copper Seal spray onthe headgasket when installing it, once it's partiall dried to the point that it's REALLY sticky, put it on the block, and install the head.
