,Oct 12 2004, 10:02 AM]Well, the first thing you should be looking at is fuel management. 300whp has been done with consistancy on stock blocks with good tuning. This dosen't really mean that you should leave your block stock, but it is an option.
If you have the money to put into block modifications, then a good set of Arias or Golden EAgle forged pistons should be on your list. Sleeving will also improve the stability of your engine, along with a full rebalance. Rods and bearings are also adviseable.
To hit horsepower like that, you are going to want to use a very large turbo, along the lines of a 60-1 turbo. A .48/.50 Hybrid might be able to get you where you want with a bit better efficency, but you'll have little room for upgrade.
[post=401640]Quoted post[/post]
